23 Mar 2017 at 15:39 #1 Coopson Coopson Associate Joined 9 Jan 2011 Posts 185 Do OCUK send you the normal heat sink and fan they take off when you buy the pre built water blocked 1080ti's ??
23 Mar 2017 at 17:17 #2 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 8,959 Im not 100% sure but i dont think they do. they send the card with the water block already on so no need for the air cooler.
24 Mar 2017 at 01:56 #3 Coopson Coopson Associate OP Joined 9 Jan 2011 Posts 185 ED209 said: Im not 100% sure but i dont think they do. they send the card with the water block already on so no need for the air cooler. Click to expand... Yeah but later when I upgrade I want the old air cooler to stick in another system or sell etc.
24 Mar 2017 at 06:24 #4 ED209 ED209 Soldato Joined 5 Nov 2014 Posts 8,959 The whole point of buying it with the block on is that you don't have to do it. If you want the air cooler you will need to buy one that comes with it and then get the water block to fit it yourself. Post in the customer care section and see what they say.
