Pre built bundle
28 May 2007
Saturn’s moon Titan
I’m lookin at a bundle here would like to no how much do you reckon they would charge me to put it into the case.
Ps has anyone got bundle into case and did it get to you without any damage in transit:
Do you mean a bespoke build - i.e. you select your own components and want to know if OcUK do this service and at what cost?
If so, yes, and they charge between £50 -£130 (guestimate on recent forum chats) from a cheap basic build to expensive component builds (i.e. not custom water) - and is covered by 3 year warranty.
If you've finalised your component list take it to the Customer Service Forum - Pre-Sales Advice - and they should be able to give you a ballpark figure there.
Just looking the bundle into the case mate and then I’ll add my other components in my self . Ssd graphic card etc.
I'm sure they would, for a price, if you ask - but suspect that it would probably be more cost effective for them to fit everything (unless buying other components from elsewhere or have them already).
That said - why? You sound quite confident rummaging around the internals of a PC - why not motherboard/CPU?
