Pre built for a friend - little help.
Hello,
My friend is looking for a full system, pre built as zero knowledge or interest in own build.
I played around with a pre built, link is below. I'm quite out the loop these days so would appreciate some input. Budget it definitely no higher than this.
No need for any other accessories but a copy of windows is needed.
https://www.overclockers.co.uk/ocuk...onfigurator-fs-01k-tl.html#t=a7b*c5d$e7fvi0j+
thats a HEALTHY Budget! whats monitor are they running, Hz and resolution ?
heads up , asus boards for z390 are naff, Aorus makes the better board
and 240 aio wont cool that 9900k!
very quick edit of your list and another one without nothing the above.. much faster GPU
My basket at Overclockers UK:
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £1,958.82
    • Motherboard:Gigabyte Z390 Aorus Pro Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Processor:Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • CPU Cooler:be quiet! Dark Rock Pro 4 CPU Cooler
    • Memory:Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C15 3000MHz Dual Channel Kit - Black (CMK16GX4M2B30
    • M.2 Solid State Drive **For Operating System If Selected**:Unwanted
    • Solid State Drive 1:WD Blue 3D NAND 1TB 2.5" SATA 6Gbps Solid State Drive (WDS100T2B0A)
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Power Supply:Bitfenix Whisper M Series 850W 80 Plus Gold Modular Power Supply
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Case Lighting:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 7 working days
    • Speakers:Unwanted
    • Gaming Chair:Unwanted
    • Case:be quiet! Dark Base 700 RGB Midi Tower Case - Black Tempered Glass
    • Graphics:Asus GeForce RTX 2080 Dual OC 8192MB GDDR6 PCI-Express Graphics Card
    • Graphics 2 (SLI/Crossfire):Unwanted
    • NV Link Bridge - Required for Dual RTX Graphics Cards:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Headset:Unwanted
    • Monitors:Unwanted
  • 1 x OcUK Gaming Hoplite - AMD Ryzen 7 2700X Gaming PC = £1,997.95
    • Processor:AMD Ryzen 7 2700X Eight Core/Sixteen Thread 4.35GHz Processor (MPK)
    • Memory:Team Group Night Hawk RGB 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - RGB Black (TF1D4
    • Graphics:Gigabyte Aorus GeForce RTX 2080 8192MB GDDR6 PCI-Express Graphics Card
    • Primary Drive:TeamGroup 1TB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Security Software:**Special Offer** Bullguard Internet Security - Anti-Virus and Security - 1 Year 3 PC
Total: £3,979.87 (includes shipping: £23.10)​
Well actually i guess i should have mentioned this, he games on a 4k TV.
Boo hiiiiisssss!!!
Ah the gigabite, cheers.
Thanks for the suggestions, I'm a little out the loop these days so the help is much appreciated.
Boo hiiiiisssss!!!
4k would be looking for 2080ti personally !
ocuk would be able to build for around £100
Total: £1,947.70 (includes shipping: £20.82)
overkill for the price and for pure gaming ! allows GPU which is the KEY for 4k gaming ! as above ^^ 2080ti is the ONLY true 4k GPU currently to hold 60 fps across any game with high settings
case bit overkill and can pick them up at half the price. just drop a link to Customer Service pre-section linking this thread and they can quote you up privately
ryzen 8 core 16 thread is slower then intels i9, but at 4k almost equal and will last a long time! Mobo is x370 so first Gen but has better VRM set up then £100 b450 and £150 X470 boards . black on black should look epic​
