Pre built options
13 Feb 2025
England
Morning all.
I’m new to PC gaming. Over the years I’ve played football manager on the laptop and that’s about it.
I’m now wanting to get into higher graphical need games such as manor lords/civ 7.
I’ve got a budget of around £1K for a PC. Any suggestions would be very much appreciated.
Thanks in advance
Hi and welcome.
This is just one option pre built which I've upspecced to a 5600 ,32gb memory, 4060ti and WiFi adapter which can be sourced cheaper.
My basket at OcUK:
  • 1 x OcUK Gaming Kalis - AMD Ryzen 5 5500 GeForce RTX 4060 Gaming PC (SKU: FS-1FT-OG) = £999.97
    • Case: 1 x Kolink Observatory MX Mesh ARGB Midi Tower Case - Black
    • Processor: 1 x AMD Ryzen 5 5600 Six Core 4.4GHz (Socket AM4) Processor - Retail
    • Memory: 1 x Team Group Vulcan Z T-Force 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
    • Graphics Card: 1 x Asus GeForce RTX 4060 Ti Dual EVO OC 8GB GDDR6 PCI-Express Graphics Card
    • M.2 Solid State Drive: 1 x WD Blue SN580 1TB SSD NVME M.2 2280 PCIe Gen4 Solid State Drive
    • WIFI Adapter: 1 x Asus USB-AC58 Wireless-AC1300 Dual-band USB Adapter
    • Operating System: 1 x Build Stock Microsoft Windows 11 Home Advanced - Systems
Total: £999.97 (includes delivery: £0.00)​
Thank you for the advice and recommendation.
Bit of a minefield trying to work this out from my point of ignorance!
There are lots of options so you have to juggle parts to get the best performance.
The above build is AM4 but still good for the Money but there is AM5 which is newer but you may have to compromise on GPU performance.
Newer build with faster CPU , 4060 and 16gb of memory.
Compare
Would the drop in memory from 32GB to 16GB have a significant effect on performance?
If I was buying a gaming PC today I would definitely try to avoid having 16GB, but most games do still work fine. It is relatively cheap and easy to upgrade DDR4 from 16GB to 32GB, if necessary.
If you could stretch to £1,075.00, there is a company offering a pre built gamin PC with 4070 Super / i5 13400F / 16gb DDR5 build that looks very good value. It's not from Overclockers so assume I am not allowed to share the link?
