Pre-built suggestions for work
2 Nov 2020
Afternoon folks,
My business partner's PC is absolutely knackered (it wasn't much use to begin with in my opinion!) and i've talked him into lumping some money in something a bit better.
He's already got a 49" curved LED monitor (I think it's the electriQ 49" IPS 5K DQHD 144Hz 1ms Super UltraWide Curved Gaming Monitor) and has mouse & keyboard, webcam & headset so just needs the tower (or laptop if someone suggests running a laptop would work better/more cost effective?)
His current tower is an Optiplex 7010 with i5 3570 3.4GHZ (4core) and 8gb of ram.
He has multiple instances of chrome and/or edge open with multiple tabs each (don't ask - drives me mad), and will also use Acrobat, Word, Outlook, Excel & Whatsapp Web all simultaneously. PC gets powered down once per week on a Friday, and we have ESET encryption software running in the background too. His machine is very slow when operating at load now having filled his 180gb SSD drive, and much of what his machine holds requires retention. I've toyed with the idea of installing another drive for him, and maybe some RAM but I think the machine itself is just a bit naff so would be more sense in a complete upgrade. I've only build gaming machines in the past, so am completely out of my depth - any suggestions would be appreciated!
Both Intel and AMD 7000/9000 PCs come with integrated graphics (except -F) models and pretty much anything will be an upgrade on the i5-3570.
The minimum I'd go for is a 12400/14400, but better if Intel would be Core Ultra like 245K.
If AMD, there used to be a lot of pre-built 4650 and 5600G PCs, not sure if that's the case now. Since the IGP in those models is very dated, I'd definitely prefer 8500G/8600G, or just the basic IGP in the 7000/9000 CPUs.
There's a review of the 8500G here:
Lovely - thankyou!
I just saw this at £750 - you think that would be a fairly noticeable upgrade?
Windows 11 Home (64-bit Edition)
AMD Ryzen™ 5 8400F
GeForce RTX™ 3050 6GB
32GB DDR5 Kingston Fury Beast
MSI Pro A620M-E mATX Motherboard
1TB WD Green SN3000 NVMe PCIe SSD
Yes, but I wouldn't recommend it, because a 3050 6GB is about £150 and they won't get any benefit from having that card over the integrated graphics (though the 8400F doesn't have any).
Edit: also important to note that the integrated graphics on many motherboards don't have a spec that matches the monitor.
Minisforum have some bonkers deals at the moment. If the machine has a significant amount of up time I’d definitely lean towards something with a reasonably recent AMD APU.
Afternoon folks
Just circling back to this - he's looking to order this weekend and I've found 3 machines that I think might do the job:
1: Dell i5 @ £579:
  • ProcessorIntel® Core™ i5-14400, 10 cores
  • Operating SystemWindows 11 Home
  • Graphics CardIntel® UHD Graphics 730
  • Memory16 GB DDR5
  • Storage1 TB SSD, PCIe
2: HP @ £707:
  • Operating systemWindows 11 Pro
  • ProcessorIntel® Core™ i5 14500 (14th Generation)
  • Memory16 GB RAM
  • Storage512 GB SSD
  • GraphicsIntel® UHD Graphics 770
3: HP Prodesk 4 @ £739:
  • ProcessorIntel® Core™ Ultra 5 235
  • Memory16 GB RAM
  • Storage512 GB SSD
  • GraphicsIntel® Graphics
Couple questions before I recommend... 1 - would any of these 3 machines represent an obvious, tangible upgrade on the Optiplex 7010 with i5 3570 3.4GHZ (4core) and 8gb of ram, and 2 - is there a big drop-off from the 2 HP models to the Dell, or a big jump from the i5 14500 to the Ultra 5 235? I found a nano-review article comparing the two and it seemed there was a marked improvement from the 14500 when moving to the 235 ultra, but thought I'd ask beforehand!
It is hard to say what is "tangible" for general desktop/office use, but in raw performance terms: yes, they're all a huge upgrade in single and multithreading performance and doubling the RAM should help with multitasking.
The 14500 has 4 extra cores over the 14400 and a better IGP, but I'd expect the improved multithreading to only be noticeable under heavy load and tasks that take e.g. 5-10+ minutes to complete.
From the description of usage that you have given, it is unlikely that the 14500 would be noticeable over the 14400 and I'd pick the cheaper PC with the larger storage.
In theory, it does have decently higher multithreading performance and the graphics have been upgraded with newer features and better pixel pushing, but realistically is he likely to notice or care? I'd say not. That said, if it was me, I would choose between the cheaper system at 579 and the newer system at 739, since the higher CPU performance, newer platform and greater feature set are a better justification for losing 500GB of storage than gaining 4 e-cores.
