Pre built systems
You cannot post links to competitors on these forums. You should remove them now.
Edit- do not buy either and remove the links.
Sorry if I came across as rude in post above. I am not a mod and did not want you to get banned without any help.
If you post budget and needs we will try and help. You can then take the advice given and spend your money where you like, it is your decision and cash at the end of the day.
The 2 PCs you linked were 11th gen and 9th gen and both are not worth it. The systems also did not say what mobo or psu they were using which makes me wary and I would hazard a guess they were rubbish. There are some excellent prebuilds available but also some awful ones so you do have to be certain what you are getting for your money.
