- 31 Jan 2018
After doing as much research as possible, I had come to the conclusion self building was the way to go and came up with this contains competitor links - removed which I think is a decent build? Although would also get more storage.
But then after looking at some pre builts https://www.overclockers.co.uk/tita...-core-i5-7600k-4.8ghz-kabylake-fs-124-og.html
I might be not seeing something I should but if I upgrade this to the same cpu and gpu, the price is slightly cheaper plus it comes with a 3 year warranty +built for me? Which overall seems better?
Any advice would be really appreciated.
