- 16 Sep 2013
- Gloucester
Hi Guys ,
Can you guys help me ,
I want watercool my system but I'm not sure what fitting and components i need
i want my system looks somethink like this
Case is Corsair 540 Air so pump and reservoir will be in "messy" side of case and tubing will go out from one of case holes
CPU 4930k
2x 780ti reference
i been looking around OCuk website and i quite like XSPC stuff
Parts what i pick up is :
1x EK Water Blocks EK-D5 Vario X-RES 140 (incl. pump) £107.99
2x XSPC Razor GTX 780 & Titan GPU Waterblock **GTX 780 COMPATIBLE** £69.95 (139.90£)
1x XSPC Razor SLI Flow Bridge (3 Slot) £8.99
1x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1x XSPC EX360 120mm Radiator - Black £47.99
1x Hardware Labs Black ICE Radiator GTS-Lite 240 £37.99
2x Mayhems Pastel - Ice White Coolant 1L £14.99 (29.98£)
1x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Clear £6.98
Subtotal £431.80
my budget is 500£
Now to the point , What/Which and how many compression fittings i will need ? and maybe some parts if i missing something ?
!!! parts must be in stock by OCuk !!!
Hope you can help me
Thanks in advance
CPU 4930k
2x 780ti reference
Subtotal £431.80
my budget is 500£
Thanks in advance
