- 31 Jan 2011
- Hampshire
What sort of water temp difference should you get before and after the cpu ? Im guessing if the flow is correct it should be fairly minimal ?
I assumed that a high enough flow would cause very little difference, however there has to be a difference, just wondered by how much.
The aslower the flow the higher the difference i guess.
I assume that in your build all the heat generating components are on the inside and the radiators are on the outside?
For normal flowrates it's about 1degC per 250W.
