- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Akasa Freedom Xone AK-BKXNE-01 Case - Black (No PSU) @ £46.99 inc VAT *** ***
Akasa Freedom products are designed to unleash the performance of your system. Freedom Xone is a cutting edge midi tower case delivering superb cooling. A “Black is Black” case with sleek black interior. The striking appearance of the mesh front panel with pure white illumination provides constant airflow.
The cool black chassis uses zoned thermal management including base mounted PSU and smart cable management giving that clean tidy system. All round easy access including rear entry to the motherboard for heatsink backplate fitting and tool free HDD installation makes system building a breeze. Full size hi-performance VGA cards are accommodated and kept cool with side panel ventilation.
- Dimensions: (H) 445 x (W) 200 x (D) 482mm
- Compatible motherboard types: MicroATX & ATX
- Full Black Interior
- 4 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- Front Cooling: 120 x 120 x 25mm, white LED, 1200RPM (front)
- Top Cooling: 140 x 140 x 25mm, black, 1000RPM (top)
- I/O Ports: 2 x USB2.0, 1 x eSATA, 1 x HD Audio
Only £46.99 inc VAT.
ORDER NOW
ORDER NOW
