** PRE ORDER NOW - RAIJINTEK AGOS & ARCADIA CASES **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
It gives me great pleasure to announce the launch of the Raijintek Agos and Arcadia cases.
Both of these chassis are priced outrageously well and I think that the feature sets on the cases will surprise you.
The Agos is an airflow optimised Mid Tower with quick release bays and plenty of cable management integration. This case is ideal for any gaming system and would even easily support multi GPU arrays and advanced cooling with zero issues.
The Arcadia is a more budget orientated line but make no mistake, the 240mm radiator support in the roof indicates that whilst this is a £25 case, there is nothing to sniff at here.
Both cases are available in a sleek black finish or an attractive and eye catching white finish.
Raijintek Agos Midi Tower - Black @ £39.95 inc VAT
Agos is the revolutionary new Mid Tower chassis from Raijintek. Developed in cooperation with German Designers and engineers, the Agos is innovation paired with classic design.
Mesh intakes provide superior airflow whilst roof mounted watercooling support offers high performance features in a superb value chassis.
Features:
- Elegant and classic design with efficient and massive airflow
- Removable 3.5"HDD cage, provides enthusiasts more convenient installation and opportunities
- Special Automotive Intake Air Design for Superior Airflow
- Enlarged front mesh
- USB 3.0 super speed port (internal)
- Whole black coated and white coated interior
- Dust-Control filters for all mesh area
- Accommodate an internal 240 mm radiator at the top
- Rear tubing holes for water cooling
- Supports 160mm height cooler, RAIJINTEK all coolers except NEMESIS
- Supports up to six fans(two 140mm and four 120mm) and six HDD(3.5" or 2.5")
- Tool-free system for ODDs and HDDs
- Supports VGA card up 410mm(remove HDD cage) and CPU cooler up to 165mm
Specification
- Dimension [WxDxH]: 200x460x490 mm
- Material: SPCC 0.55mm
- Color: Matt Black
- M/B Support: ATX, MicroATX
- Drive Bay: External 5.25" [Tool-Free] *3
- Internal: 3.5" [Removeable, Tool-Free] or 2.5" *6 [Removeable]
- Expansion Slot: PCI Slots [Tool-Free] *7
- I/O Panel: USB3.0*1, USB2.0*1, HD Audio*1
- Power Supply: PS/2 [Internal Bottom-mount]
- Water Pipe Holes: 2
- Front Fan: 120mm*1pcs [pre-installed] ; 2pcs [option]
- Rear Fan: 120mm*1pcs [pre-installed]
- Top Fan: 140mm*2 or 240mm radiator [option]
- Bottom Fan: 120mm*1 [option]
- Left and right side Fan: 120mm*2 or 140mm*2 [option]
- CPU Cooler Height 160mm [Max.]
- Graphic Card Length: 290mm [with HDD cage]; 410mm [without HDD cage]
- Side Panel Style: Flat
Only £39.95 inc VAT.
ORDER NOW
Raijintek Agos Midi Tower - White @ £39.95 inc VAT
Features:
Specification
- Color: Matt White
ORDER NOW
Raijintek Arcadia Mid Tower USB 3.0 Case - Black @ £24.95 inc VAT
The Arcadia is a Mid Tower chassis where pure innovation meets classic design, combined with high
Airflow through large mesh intakes in the front panel provides ample cooling to performance components. The Arcadia also features water cooling support in the form of a 240mm radiator bracket in the top panel.
Arcadia presents a new ethos in an affordable case range. Laden with attractive, premium features, the Arcadia manages to present an enthusiast class experience into a product with a small price tag.
With numerous technical features, the Raijintek Arcadia offers end users a host of options previously unthinkable at this price point.
The Arcadia is perfect for system builders and performance enthusiasts.
Features:
- Dust-control filters for all mesh area
- Supports VGA card up 400mm
- Elegant and classic design with airflow efficiently and massively
- Sport car theory of inlet air design for superior airflow
- Supports up to 4 fans (four 120mm) and 6 HDDs (3.5” or 2.5”)
- Whole black coated interior
- Supports 160mm height cooler, Raijintek all coolers except NEMESIS and THEMIS Evo
Specification:
- M/B Type: ATX/MICRO ATX
- Power Supply: PS-2
- Power Supply Integration: Internal Bottom PSU
- 5.25" Drive Bays: 2
- 3.5" Hidden: 4(1 exposed + 3 hidden)
- 2.5" Device: 2
- I/O Panel USB3.0 * 1 + USB2.0 *1; HD Audio x 1
- PCI Slot: 7
- ODD Tool-free
- HDD Tool-free
- Fan Filters
- CPU Cooler Height: 160mm max.
- Graphic Card Length: 400mm
- Cable Management Regular
- Water Pipe holes: 3
- Front Cooling Fan 120mm: 1 (option)
- Rear Cooling Fan 120mm: 1 (pre-installed)
- Top Cooling Fan 120mm: 2 or 240mm radiator (option)
Only £24.95 inc VAT.
ORDER NOW
Raijintek Arcadia Mid Tower USB 3.0 Case - White @ £24.95 inc VAT
Features:
Specification:
- 2.5" Device: 2
- PCI Slot: 7
- ODD Tool-free
- HDD Tool-free
- Fan Filters
ORDER NOW
Fair enough they are cheap but not even supporting their own coolers? Am I the only one to read that and think wtf?
