PRE-ORDER PRICE SPECIAL
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
Stock of the black is due in about 10-14 days, the Metallic Grey is about a month away. We have a special pre-order price of £83.99inc. The pricing will go up to at least £89.99 once the stock lands. So grab a deal now prior to arrival.
CM Storm Scout II Midi Tower Gaming Case - Black @ £83.99 inc VAT
CM Storm Scout 2 - The long awaited successor to the infamous Scout is ready to be deployed! The Scout 2 follows a more round futuristic theme and features improved steel reinforced carrying handles, bolted to the core structure. The front console has been upgraded to USB 3.0 for high power charging and lightning fast file transfers, and can be hidden and protected from dusty battlefields, friendly fire and melee attacks behind a slide cover. The 1st HDD cage can now be removed, to support monster VGAs like the NVIDIA GTX 690 and AMD HD 7990, turning it into a powerful Battlestation.
- Materials: Polymer, Coated Steel Mesh and Body
- Dimensions (W x H x D): 230 x 513 x 517.5mm / 9.1 x 20.2 x 20.5 inch
- Net Weight: 8.3 kg / 18.3 lbs
- Motherboard Type: Micro-ATX, ATX
- 5.25" Drive Bays: 3 (exposed)
- 3.5" Drive Bays: 7 (hidden)
- 2.5" Drive Bays: 2 (converted from one 3.5" drive bay)
- I/O Panel: USB 3.0 x 2 (int.), USB 2.0 x 2, Mic x 1, Audio x 1 (supports AC97 / HD Audio)
- Expansion Slots: 7
- Top Cooling: 120mm fan x 2 (optional)
- Front Cooling: 120mm fan x 2 or 140mm fan x 1 (optional)
- Rear Cooling: 120mm red LED fan x 1 (with LED on/off function)
- Bottom Cooling: 120mm fan x 1 (optional)
- Side Cooling: 120mm fan x 2 (optional)
- HDD cage Cooling: 120mm fan x 1 (optional)
- Power Supply Type: PS2
- Maximum Compatibility: VGA card length: 287mm / 11.3 inch (with HDD cage); 399mm / 15.7 inch (without HDD cage)
- CPU cooler height: 147mm / 5.8 inch (with side fan); 162mm / 6.4 inch (without side fan)
PRE-ORDER PRICE - Only £83.99 inc VAT.
ORDER NOW
CM Storm Scout II Midi Tower Gaming Case - Metallic Grey @ £83.99 inc VAT
ORDER NOW
