- 17 Oct 2002
- Stoke
The Titan Fenrir features four larger 8mm diameter copper heat pipes with a direct-touch design to maximize the overclocking performance up to 160w and succeed in offering the best cooling performance. The 120mm fan with built-in PWM speed control technology will operate automatically to solve overheating problems and provide a silent environment.
- Socket Type: AMD 754 / 939 / 940 / AM2 / AM2+ / AM3 / Intel LGA775 / LGA1366
- Dimensions: 156mm x 124mm x 107mm
- Fan Dimensions: 120mm x 120mm x 25mm
- Fan Connector: 4-Pin (PWM)
- Fan Speed: 800 - 2200 RPM
- Airflow: 33.2 - 78.41 CFM
- Noise Level: 17.2 - 39.0 dB
Just £32.99 inc. VAT
BUY NOW
