Pre overclocked bundle question.
30 Aug 2009
I brought this: http://www.overclockers.co.uk/showproduct.php?prodid=BU-003-OB last week and its mainly a question on the memory and if its all correct.
As shown on my CPU-Z report the processor is at 4010mhz
but RAM speed is shown as 764MHz ?
http://valid.canardpc.com/show_oc.php?id=680703
Is this because the RAM has been lowered to allow for the higher CPU speed or am I not understanding something about this type of memory? I've been out of the OC/Hardware scene for a while now and I just need a quick refresh on whats happening and whether this is really the best the PC can run at?
I've not altered any settings pre-set by OCUK and is as it come out the box.
Please help...
P.S hi all, on my first post :)
thats fine mate. its down to the blck being 191mhz and not 200mhz. its an easier way of 4Ghz with stability. I would set the timings to 8,8,8,24,2t XMP = off, performance enhance = standard, voltage = 1.5v
It's because they used a 191Mhz BCLK with 21 multiplier, they should have used 200 BCLK with 20 multi and disabled turbo.
