Pre-pc running boot.
28 Jan 2011
Hey guys.
My pc is running fine, but now what it does is when I boot it up after a few seconds it turns off and the restarts again then boots windows.
Is this a problem or what?
RTJ
If your overclocked then this is can be normal, my boards have done this in the past.
What board are you using.
Check for latest BIOS, my Gigabyte x58 used to do that but with the latest BIOS version it keeps the fans ect on, but you can tell the board is applying the overclock.
But don't worry to much.
my evga board does that when you've switched it off at the mains next time you turn it on but never when its just been shut down learn some thing new every day :D
