Hi,
I'm looking to purchase a pre-built machine (Work a lot and don't really want to mess it up).
Main uses:
- WoW
- Work (Web Development)
Ideally I'd like to be running WoW at high settings reasonably well during raids etc; looking for something that is reliable as well though due to using it for work when needed. Also needs to stay at a reasonable temperature - having the boiler in the same room raises the temperature of just about everything it seems..
Budget: ~£900, though this is flexible.
No monitor/keyboard etc needed.
Thanks.
Main uses:
- WoW
Thanks.
