precision screwdrivers
12 Apr 2007
Can anyone suggest a set of quality screwdrivers? I've had a few sets over the years but all have been quite rubbish... the shafts start twisting with too Much pressure, generally poor quality.
Thanks
focus own set, they have a slightly fatter Handle so you get more power into them without it hurting your hand because the shaft is to thin.
They look quite decent, The main issue I had was those slim metal handles on the cheap ones, no grip and the Guos tend to slip inside the handles. Will check these out, thanks!
