Predator XB1 27" 144hz 1440p Monitor - Strange Faint Grey Vertical Lines??? HELP
27 Nov 2012
Got my new Monitor the other day, but immediately noticed when the screen displays a light colour, there are very faint grey vertical lines all along the screen, they can only be seen depending on which angle you look at the screen, but looking head on they tend to show about 6 inches in on either side of the monitor, they are very faint but noticeable when a light background is displayed.
They don't show up on a picture of the screen, but quite visible to the eye, if you change the angle you view the screen it shows up in other places depending on where you look and move your angle of view around
Is this normal/ anyone else experienced this? a problem with TN Film panels?
I don't want to return only for the replacement to have the same issue?
Help
This image isn't mine, found it online on another forum but its best wy to show & describe what I'm seeing, the vertical lines appear like that, but much fainter, and only visible on light backgrounds, also not all visible at the same time, only patches depending on viewing angle?
Did you get anywhere with this? I just picked up a used Predator XB271HUA (TN Panel) and have noticed the same, it's a little distracting
