Predictive text
6 Jan 2013
Rollergirl
What's going on with the forum software? I use Gboard and the text input box just makes up random words. Also, if the prediction was wrong I used to select the correct one and it would update, but now it's a lottery which word will be inserted. If I go to the middle of a sentence to change something, the words in front will start to change too!
It only happens on OcUK and it didn't happen previously, even with the new software.
:confused:
swiftkey is far better than google keyboard for predictions.
I gave gboard a go for a few months and it was just terrible.
It's an issue with SwiftKey on Android, my phone would type random letters and when I selected the correct prediction from the top row it would just shove in random letters.
Only just sorted this out yesterday after some Googling, quite coincidentally I was going to start a thread about it.
It will be rolled out with an update soon but if you want it to stop then you need to install SwiftKey beta to solve it.
I was having odd issues on here with it, turned off the wysiwyg editor and its fine then. Only had the issue with the xenforo editor
What a load of bull shirt. Nothing wrong with my predictive text, stop talking shirt. Ducking idiots.
Yeh and the other day we were there and we were a bit off the road to the airport to get the OTA in the UK recently with the car insurance policy in the first instance though.
Even trying the swiftkey beta, the rich text editor is still broken, trying to use any punctuation just results in double spaces instead. Only get this on xenforo.
Back to turning off the rich text editor it is.
