Prefect case
19 Feb 2009
So yeah like the title, what would you guys recomend as a perfect case for space, cable management and watercooling.
Spec will have..
GeForce GTX 295
Asus Rampage II Extreme Intel X58
Intel Core i7 920
and ofcourse all the other bits.. if that not enough info, i will edit the lot in, and one other thing any one recomend a decent watercooling kit to go with the case external or not, the case in mind was a Coolermaster RC-1100 Cosmos S, thanks for any replys.
Look great indeed with all the space.. hard part for me is looking for the right watercooling things, feel like im getting nowhere. my spec is all fin just the case+watercooling.
Perfect case is impossible: It would need to have lot of space but for moving around it should be also small and light enough. :D
Lian Li A70/71.
They are also very affordably priced. (fair 100 cheaper)
Plenty of space, you can throw up to triple radiator to top (top with ready made holes available if you don't want to start cutting) and retain all seven soft mounted front HDD bays and most 5.25" bays.
And with some work you can hide cables really well:
http://www.nordichardware.com/Reviews/?skrivelse=532&page=5
I got the TJ07, and its near to the perfect case for watercooling, not quite perfect, but is the best around
TJ07 is the best, depends if you want to spend that much though. It'll probably be worth it in the long run. Cosmos S is also very good, and if you got that you could spend more money on the watercooling. I would go with the TJ07 though, they are lush.
