Hi,
Just double checking, if I'm heavier than what the manufactures settings were set for then I should make the Preload stronger and the rebound damping force larger. That right?
Just tinkering and noticed that the previous owner had it set very lower, he wasn't tiny either so not sure why.
I'm not experienced enough to play around properly but figure I just have it set correctly and work from there.
Cheers
Cheers
