Premade Bundle vs Making my own?
Yeah I noticed. :( It's probably better to go for the one with the none transparent anyway so I can maximise cooling. So I read that the Trooper has positive air pressure, thats something I would want to keep correct?
Corsair A50 Heatsink dimensions 159.5mm x 124.6mm x 81.2mm
The width of the case and convex side panel we have up to 186mm for the CPU cooler height.
Most 120mm fans are 25mm in depth.
So 159.5+25=184.5mm. Which only leaves 1.5mm clearance. A bit tight.
The Hyper is 4mm taller. The height of the cooler is`nt the problem. The distance between cooler and side panel, is the problem. If you wish to install a fan on the panel, you may have to find a fan with a depth smaller than 25mm.
Ahah umm ones Yates Loon the other was Scythe Kaze. The Kaze are 12mm depth the Yates are 20mm depth. So I can have either a 6.5mm gap or a 14.5mm gap. But Im unsure about the Kaze fans :/ apparently they are quite loud.
