hi guys computer i made in 2007 from this website has stopped working after transporting it in the car while moving house, upon power up it keeps turning on and off constantly. After having a friend take a look at he reckons its the motherboard unfortunately for me I cant find a replacement motherboard. So I guess my only option is to upgrade and sell my old ram and cpu.
I have had a look at 3 options but since I haven't been active in the computer market for the past couple of years I don't know which is better
1)
2) http://www.overclockers.co.uk/showproduct.php?prodid=BU-080-OE
Cost £363.18 upgraded option 8gb ram
3) http://www.overclockers.co.uk/showproduct.php?prodid=BU-078-OE&groupid=43&catid=2053&subcat=
cost £380 upgraded option 8gb ram
First of all thanks a lot guys and if there is anything else you would like to suggest please do so
, budget is around 350-400, I have no experience with over clocking so the first option will probably remain at stock unless I learn how to over clock
would like to use everything else from my old pc build is as listed below:
Akasa AK-15-NSBLPC Blue Neon String 150cm - Internal Kit £7.99 1 £7.99
Akasa AK-178-RD 12" Cold Cathode - Red £7.99 1 £7.99
BFG GeForce 8800 GTX OC2 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £329.99 1 £329.99
OCZ GameXStream 600w Silent SLI Ready ATX2 Power Supply £49.99 1 £49.99
Samsung SH-S183ABEBN 18x18 DVD±RW Dual Layer Serial ATA ReWriter (Black) - OEM £17.99 1 £17.99
Western Digital Caviar Blue 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) £56.99 1 £56.99
Asus P5K Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £124.99 1 £124.99
Intel Core 2 Quad Pro Q6600 "LGA775 Kentsfield" 2.40GHz (1066FSB) - Retail £149.99 1 £149.99
1)
would like to use everything else from my old pc build is as listed below: Akasa AK-15-NSBLPC Blue Neon String 150cm - Internal Kit £7.99 1 £7.99
