Premier Pro Doubts
8 Mar 2005
Cardiff
Howdy all
I've been using Premier Pro for the past couple of years as I don't have an Mac but I'm getting increasing fustrated with it. Not only does the program have major stability problems but general effects and editing options are fairly limited.
Are there any other alternatives that you consider superiour to Premier or shall I continue to use it untill I get my hands on a Mac, maybe obtaining after effects or other Adobe progs.
Thanks
I get along fine with premiere pro. What kind of thing are you editing - if it isn't anything that major you could use something like iMovie if u get a mac.
