Premier Pro, setting up where to store cache, project files etc
7 Jul 2008
Newcastle upon Tyne
First the PC spec so you know what I am working with:
Intel i7-5820
32GB DDR4 Ram
Gforge GTX 960
OS drive 256GB N.2 PCIe SSD
Data 2tb mechanical hard drives
256GB SDD
125GB SSD
Win 10 Pro
So I obviously the program on the OS. My finished work is on the 2tb drive which is backed up daily.
So I need help re scratch disk, cache disk, project files and media
I've got the scratch disk, cache disk, project files and media files all stored on two mechanical harddrives. Personally I'm perfectly happy with the performance I've got with that set up.
I'm sure you can probably find reviews online of how using SSD's effect speeds in Prem Pro.
I guess there are a few variables, which someone must have tested out. If Cache or media is better on a SSD for example.
Have a look at this thread. https://forums.adobe.com/thread/662972?start=0&tstart=0
I do project files and media on one drive (ideally SSD) and cache and scratch on SSD. Personally, with your setup, I'd put my completed work on the 2TB, working files on the 256 SSD and cache and scratch on the 125.
