Hi all,
I'm preparing myself for the jump into the wonderful world of Linux. My current setup has two NTFS drives, one holds Windows XP (WD ~75GB Raptor) and the other is used for storage (WD ~150GB). I'm going to place an order for a third drive, (WD 500GB) which will become my primary storage drive while the current storage drive will play host to Kubuntu.
Ideally I want all three of these to be in the NTFS format with all drives being read/write accessable in either OS, however I'm not sure if this is an effective solution and would appreciate your thoughts...
I've been reading up and found there is some support for NTFS read/write from Kubuntu so I don't think this will be a problem, however I'm unsure if Kubuntu can actually be installed on an NTFS drive or even if it is wise to do so.
Finally, if you have any additional words of advice for a brand new user of Kubuntu (I do use Linux at work but I think our machines have Redhat or something, we have to RSH/SSH onto the boxes through our windows desktops using Putty or Exceed) then feel free to share it
Thanks for any help you can give,
Averick.
P.S. I'm going to buy some DVD-R's for writing the Kubuntu OS, my drive can write to both +/- R and I couldn't really see a difference between the two so I stuck for -, is this the best course of action?
.Thanks for any help you can give,
Averick.
