I'm not getting any lights on the front to confirm its charging and the battery isn't getting warm. The corner of the laptop where the adapter plugs in is warm so I'm thinking the charger is ok and its probably the battery?
It certainly does (or should do) because I've done that with my laptop at home.
If there is no lights on then it could be either the PSU (borrow a replacement off a mate to test if you can) or possibly that the whole system has just died but that is a bit more unlikely.
