Presentation/Show for plasma
13 Nov 2003
Manchester
Hi All
I need to make a presentation in Flash to be displayed on plasmas, which is no problem at all.
However does any one know what kind of resolution/ratio I should use for it?
It may be worth mentioning that its going to be burnt to DVD. I want to be sure of filling the screen
not really sure if the post fits here, it doesnt really fit home AV kit forum either tho :)
Thanks
Aaron
if you save the flash presentation as a movie and conver it to dvd using WinAVI or similar program that should work.
Thats what I am going to do. Dont suppose anyone knows the screen size, in pixels of a standard (non hd) plasma.
Ta
Aaron
