Press F1 to continue Fan Error
30 Mar 2009
Okay so I have a new system setup with a Laing DDC-1T plus pump and I have wired up the blue wire to the CPU fan header and I am getting the fan error, should that be reporting the RPM of the pump to the fan CPU header or can I just ignore it?
That's odd, it should be working, does your Motherboard have two CPU fan headers? I.E a main and optional one? could be complaining as one is not connected, the RPM on a DDC will be more than enough to satisfy a CPU fan speed check.
Would a motherboard detect no voltage is being used therefore disregarding the rpm as a functioning fan?
I just turned mine off in the bios it wasn't happy regardless of what was plugged into it haha.
Yeah that is what I have done but I kinda like the idea of being able to see the RPM of the pump so that I can get some warning if it breaks down :)
