I have a very old Karcher K2.29 that has died, the pump still works but water shoots out of the front of the casing when you turn it on. I was hoping it was the cheap (a fiver) plastic hose connection elbow that had split, which apparently is a common fault. After opening it up to check this is fine and the water is actually shooting out of various different places on the main housing of the pump. I think I only paid about £30 for this pressure washer well over a decade ago and the parts to repair it are going to be more than it's worth. I want to replace it but (unbelievably) they seem to cost more than £30 for a new one these days! Whilst I'm aware there are better options than Karcher, I would ideally like to get another Karcher so I can continue to use the existing hose and foam lance I have. I was hoping to find somewhere selling refurbished ones minus any accessories for cheap. But I can't find any. What other brands of pressure washer share the tool/hose fittings? Does anyone know where I can get just the Karcher bare units?
Thanks
Dave
Thanks
Dave
ff&rh=n:114633031,k:Nilfisk+pressure+washer&keywords=Nilfisk+pressure+washer&ie=UTF8&qid=1521634239&rnid=1642204031
