Pretty dense sql query
8 Mar 2005
London, UK
Hopefully a very simple one:
SELECT monthyear, COUNT(*) AS callcount, SLAPass
FROM vw_RAA_RA
WHERE (TICKET_ID_ IS NOT NULL) AND (Actual_Date >= DATEADD(month, DATEDIFF(month, 0, GETDATE()) - 11, 0))
GROUP BY DATEADD(month, DATEDIFF(month, 0, Actual_Date), 0), monthyear, SLAPass
The above query produces 3 columns as follows:
Monthyear,callcount,SLAPAss
Jan2012,10,No
Jan2012,8,Yes
However, what I want to do is crosstab, I suspect, the result as follows:
Monthyear,callcountFail,callcountPass
Jan2012,10,8
Any guidance most welcome, I'm even less than a total noob when it comes to sql so please be gentle.
Cheers, Paul.
If i've understood correctly, you should be able to do something like:
Code:
SSELECT DATEADD(month, DATEDIFF(month, 0, Actual_Date), 0) AS MonthYear,
	SUM(CASE WHEN SLAPASS='No' THEN 1 ELSE 0 END) AS CallCountFail,
	SUM(CASE WHEN SLAPASS='Yes' THEN 1 ELSE 0 END) AS CallCountPass
FROM vw_RAA_RA
