Do a Push&Pull config, works for me. Electric sticky tape helped me seal up the holes between the outside fan pushing onto the 120.1 radiator in my setup.
I you have to go for a single fan, I *think* pull is your best bet, as pushing air is dissolved slightly by the resistance of the fans. Since you want air to move away from the Rad, I'd bet money on pulling being the better option.
