Prevent duplicate rows....excel
14 Dec 2005
I have a macro set up which takes the values of various cells on 1 sheet, then puts them in to (the first empty) single row (so it's easier to look through entries) on another sheet when the macro runs.
Is there any way to prevent the exact same thing being entered twice?
I have a yes no box asking to confirm if you want to enter the details and create a new row on the list sheet just now but you could just keep entering the same thing multiple times.
Any way to prevent that?
Do a find on the the data your macro has already put in, and if it sees that it is already been copied, ignore it and move on to the next entry to add.
