- 29 Sep 2004
- Hull, UK
Does anyone else have problems with this resolution? I've googled it and all I can find is a few comments on a Widescreen dedicated site that aren't particularly helpful.
I have applied the 1.1 patch and when I change the resolution to anything widescreen my monitor loses it's signal (Viewsonic 2025). This doesn't correct itself when I ALT & F4.
I have tried putting some resolution settings in the .cfg file but this doesn't help either. From what I can find a lot of people are itching for the next patch so should I just play it in 1280 x 1024 'til then?
Any help would be appreciated
Dang I should've got it for 360... less hassle...
