- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Antec CP 850W Modular Power Supply
Antec introduces the next stage in power supply evolution: the CP Series, an entirely new form factor design made exclusively for Antec’s most cutting-edge cases, such as the Twelve Hundred, P183 and P193. Delivering an excellent price-to-performance ratio, the CP-850’s extended form factor design allows for improved component selection, better circuit board layout, more room between components and a straight-through air path to take full advantage of the large 120mm PWM fan. With 80 PLUS® certification, NVIDIA™ SLI™-Ready certification and Advanced Hybrid Cable Management, the CP-850 is a cost-effective, high-performance solution for your Antec case. And with Universal Input and Active PFC for an improved power factor value, Antec’s CP-850 provides 850 watts of stable power for even the most demanding Antec system. So slide that old power supply to the side; there’s a new form factor in town.
- Larger Form Factor: allowing better airflow and reducing costs.
- NVidia SLI-Ready
- Quiet 120mm cooling fan
- Four 12Volt output rails
- Two 8pin (6+2) PCI-E connectors
- Two 6pin PCI-E connectors
- SATA connectors for Serial ATA drives
NOTE: This PSU only fits into the Antec P183, Antec P193 & Antec 1200 Gaming Cases.
BUY NOW for only £96.99 inc VAT.
- NVidia SLI-Ready
