- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Antec Skeleton Performance Chassis - Black/Silver (No PSU)
The Antec Skeleton is a truly revolutionary enclosure. With a unique design that allows for unprecedented airflow, a front 92mm fan, and a top three speed 250mm fan with multicolor LED customization, the Skeleton goes utterly unmatched in stylish cooling. Factor in the layered component trays for top-notch convenience, as well as the rackmount quality side rails, and you have a case truly without equal.
- 4 Drive Bays
- External: 2 x 5.25”
- Internal: 2 x 3.5”
- Optional: 4 x 3.5” side panel mounted drive trays
- Layered tray design for greater system integration flexibility
- 7 Expansion Slots including room for 11” video cards
- 1 top 250mm TriCool 3-speed multi color customizable LED Fan
- 1 front 92mm HD cooling fan
- 2 x USB 2.0
- 1 x FireWire (IEEE1394)
- 1 x eSATA
- Audio (AC97’ and HDA compatible) In and Out
- 13”(H) x 14.8”(W) x 16.5”(D)
- 31.75 cm(H) x 37.6 cm(W) x 41.9 cm(D)
- Net: 15.5 lb / 7.02 kg
BUY NOW for only £104.99 inc VAT.
- 4 Drive Bays
- 2 x USB 2.0
- 1 x eSATA
