** PRICE DROP ** Coolermaster CM-690 Case
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Coolermaster CM-690 Dominator Case - Black (No PSU)
When looking at the CM 690, it's easy to be taken in by its bold lines and superb styling. But don’t let its exterior fool you – the CM 690 is a lot more than just a pretty face. By utilizing a unique mesh design, the CM 690 effectively blends together both form and function, offering users a mid-tower chassis without compromise.
- Accommodates up to seven 120 mm fans for high-efficiency ventilation
- Removable HDD racks provide for easy assembly
- Cable management design for better cable routing and neatness
- Tool-free user-friendliness for quick maintenance and upgrade
- Roomy interior supports nVIDIA G80 SLI configuration
- 5.25" Drive Bay 5 Exposed (without the use of exposed 3.5 inch Drive Bay),
- 4 Exposed (with the use of 3.5 inch Drive Bay)
- 3.5" Drive Bay 1 Exposed (converted from one 5.25 inch Drive Bay)
- I /O Panel USB 2.0x2, IEEE 1394 x1, MIC x1, eSATA x 1,
- SPK x1 (support HD Audio)
- Cooling System Front :120 mm Blue LED fan x 1, 1200 rpm, 21 dBA,
- Rear : 120 mm standard fan, 1200 rpm, 21 dBA,
- Top : 120 or 140 mm fan x 2 (optional),
- Bottom : 120 mm fan x 1 (optional),
- Left: 120mm fan x 2
- nVidia Certification
- Expansion Slots 7
BUY NOW for only £54.99 inc VAT.
