Hi Guys
we have good stock of the Razer Carcharias and the price has just had £10 lopped off it. Grab yours now!
Razer Carcharias Gaming Headset for PC and Xbox 360 @ £59.99 inc VAT
The Razer Carcharias Gaming Headset for Xbox 360/PC is a circumaural gaming headset designed for extended hours of gameplay with superior gaming audio, clarity, and bass. Get ready to experience extreme comfort with circumaural ear cups and interchangeable ear cushions.
Just like its ferocious predecessor, the original Razer Carcharias, the all-new Razer Carcharias for Xbox/PC delivers superior, realistic audio with clarity and deep, thumping bass.
The in-line remote control provides fast and easy controls over volume as well as the voice and game volume balance, making this headset perfect for Xbox LIVE gaming. The adjustable, noise filtering microphone is tuned for clear voice communication. A complete and comfortable gaming communications package, the Razer Carcharias is fully geared and ready to plug-and-play with your Xbox 360 or your PC.
Adjustable voice and game volume balance.
Keeping the superior clarity and deep, thumping bass created by using the highest quality drivers available, the Razer Carcharias for Xbox 360/PC now comes with a new in-line remote control to adjust the voice and game volume balance, ideal for Xbox LIVE gaming.
Extended comfort circumaural design.
From tank battles on a beachhead to blasting the undead in outer space, the full over-ear coverage ensures a comfortable fit. With a fully adjustable, padded head rail that extends an extra 1.25 in/3.18 cm on either side to accommodate a wide range of head sizes, and with its soft, pliable, removable ear cups, the Razer Carcharias for Xbox 360/PC always allows for a perfect fit.
Connectivity to all Xbox 360 systems.
Whether your console is legacy or current-gen and connected to a display via HDMI or component/ composite, the Razer Carcharias for Xbox 360/PC is ready to go right out of the box. All required cables and adapters are included to ensure you can connect to any Xbox 360 within minutes.
Headphones
• Frequency Response: 20 - 20,000 Hz
• Impedance: 32 O at 1kHz
• Sensitivity (@1kHz, 1V/Pa): 102 ± 4dB at 1 kHz Max
• Input Power: 200 mW
• Drivers: 40 mm, with Neodymium Magnets
• Inner Ear Cup Diameter: 50 mm / 1.97”
• Cable Length: 3 m / 9.84 ft
Microphone
• Frequency Response: 50 – 16,000 Hz
• Signal-to-Noise Ratio: 50 dB
• Sensitivity (@1kHz, 1V/Pa): -37 ± 4dB
• Pick-up Pattern: Unidirectional
• Cable: 3 meters, Braided Fiber Sheath
• Connector: 3.5 mm combined jack (headphone and mic)
Was £69.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Headphones
Microphone
Was £69.99 Inc. VAT
ORDER NOW
