hi there i plan to build in janaury with vista for about £650.
I would like to get a core 2 duo, about 2gig ram, and maybe a dx10 card but prob a dx9 7900, and a 19" widescreen.
Do you think that the prices will have dropped for the above by then as it is quite expensive at the moment, i was thinking the release of the refreshed set of core 2 duo and the quadro may bring prices down for the core 2 duo current.
Thanks for any replys,
Stopsign
Stopsign
but windows 64bit pro isnt bad. I hate how you have to buy a new copy of vista everytime you replace some hardware.
