3 Feb 2010 at 14:31 #1 bigjimmyauk bigjimmyauk Soldato Joined 23 Nov 2009 Posts 6,041 Location North Leicestershire gotta go out for an hour in 10 minutes is it safe to leave prime 95 running while i'm gone?
3 Feb 2010 at 14:41 #2 Ricardox1 Ricardox1 Associate Joined 4 Sep 2009 Posts 370 Location Stoke Yea just make sure you leave something like realtemp running to check temps when your back, as long as you have proper cooling you should be fine.
3 Feb 2010 at 14:43 #3 bigjimmyauk bigjimmyauk Soldato OP Joined 23 Nov 2009 Posts 6,041 Location North Leicestershire Ricardox1 said: Yea just make sure you leave something like realtemp running to check temps when your back, as long as you have proper cooling you should be fine. Click to expand... ok thanks well i just set my baram up in push/pull today up to now been running an hour and only hit 44 degress which i think it pretty good
3 Feb 2010 at 14:48 #4 Ricardox1 Ricardox1 Associate Joined 4 Sep 2009 Posts 370 Location Stoke Yep will be fine mate
