Prime 95
22 Feb 2006
Hi guys wondered if you could help, downloaded Prime 95 to stress test my CPU, I have an amd x2 4200 so i need to have two instances running at once, anyone know how i get the second instance running ?? cos i cant figure out how too :D
download the zip version. then extract it into another folder away from your current prime install. now you can run them both at the same time. :)
