Prime 95
8 Feb 2004
North West
Running stress test (Blend) on Prime 95 with 4 threads. All was ok but the computer just randomly rebooted? is this ok? Temps were about 49 under load on all 4 cores
Here are the results so far:
[Mon Sep 22 14:00:49 2008]
Self-test 1024K passed!
[Mon Sep 22 14:17:00 2008]
Self-test 8K passed!
[Mon Sep 22 14:33:04 2008]
Self-test 10K passed!
[Mon Sep 22 14:48:20 2008]
Self-test 896K passed!
Then it just ramdomly rebooted :confused:
Thanks
A reboot is about as bad a failure as you can get with Prime95.
Keep tweaking.
Could be any one of the CPU, PLL, VTT/FSB Term or NB voltages. Also make sure your memory is running within spec.
I think PLL voltage is set to auto in the BIOS? what PLL voltage would you recommend? the CPU is clocked at 3.4GHz with a V-Core of 1.19375V
Also heard that PLL stops jitter in the data right?
Thanks
Temps so far under stress in Prime
This look ok as well as the voltage? V-core is at 1.20000V
Temps look fine, voltage is dependant on how good your chip is, not sure what the recommended max voltage for these.
