Blend uses the RAM a lot so the CPU will spend a lot of time (in CPU terms) waiting for data compared to small, which is stored in the CPU cache so the CPU is kept far busier.
Like Jokester says though, if you run Blend for long enough it will eventually run some small and your temps will go up much the same.
