blend/LinX will throw up errors in a matter of minutes.
I use SuperPI for a quick check (if it fails that, it'll definately fail others so it's back to the drawing board...) then if it passes SuperPI, I use IBT, Prime95, LinX and wPrime
Nothing like being sure! LOL
Note: not all at the same time
or C2Q if people start asking £20 for them lolAs above, I still find Prime reveals errors after 8 hours or more, that IBT and LinX don't show up.
I use IBT to test a basic level of stability first though.
Yep, still got a bit of testing to do, strangely though ive never had any issues with windows.You've got an extremely unstable overclock there.
If it fails Linx or Prime95 "Blend" after even hours of testing it will come back to bite you when you least expect it. BSOD's, random system file corruption and strange behavior in Windows are the joys of running such an unstable overclock.
Even Prime95 "blend" for 12 hours isn't enough. I prefer a custom blend from 1024-4096k. 1280k and 2048k seem to fail the most.
