I wanted to do a stability test on my OC and I'm using Prime95.
However last time I ran it once I clicked stopped nothing happened. It was a bit of an anti-climax so I just wanted to check I was running it right.
I open up P95, a box pop ups titled "Run a Torture Test" I select "Blend (tests some of everything, lots of RAM tested)". I leave the number of torture test threads to run at 6 because my processor is a 1100t and I presume that means cores.
Then I hit "OK" and it starts popping up dialogue and the icon goes green at the bottom right.
Is that all I do? Then I leave it running and if no errors pop up then I'm fine?
