Prime95 Error
26 Jun 2010
Hartlepool
When running Prime 95 Blend on my rig im getting 1 Error on core 2 can someone advise what voltages to bump up? its getting to 4hrs before the error.
already ran memtest86 so memory look fine, and temps maxing out at 68c.
Try running 4.5-4.6ghz if it doesn't fail it will probably be more vcore that you need to get 4.7ghz stable, or just run at 4.6ghz and you probably won't have to worry about instability again. :)
Cheers mmj uk, tried that when i never got an answer. think i got it sorted now its done 5hrs 30min now and no errors yet. i bumped up the vcore to 1.380 and it looks good so-far.
Thanks for the reply bud.
