Ok, so I have a Phenom II x4 810 (yes it's a bad CPU but I already know that). I OCed it to 3GHz using the BIOS and ran the AMD OverDrive Stability Test for an hour.
It was successful in AOD so I ran the Prime95 Blend test.
After 5 minutes the Worker 2 and Worker 4 failed at the same time, even though my CPU was at 42c and Mobo at 38c (according to PC Probe).
Is there any reason for this? I have no screenshots but I can get them if needed. Worker 1 and Worker 3 continued after the other ones failed until I switched Prime95 off.
Thanks in advance.
Thanks in advance.
