My system:
Mobo: BFG nVidia 680i SLI
CPU: E6600 Core Duo 2.4 (Arctic Cooling Freezer 7 Pro)
RAM: 4x1 Gig SLI OCZ 8500 (with cooling fans)
nVidia 8800gts 320mb GFX
650w decent power
Vista Premium
I've been having problems with temps ever since I built this machine. At stock the CPU temps were always around 40 idle, but didn't have much cooling in at the time. have added extra since then.
Had to RMA the RAM (just arrived back today) so all 4 are brand new (bought 2 extra while awaiting the RMA).
Have been trying my n00b OC and it has been running ok but haven't tried any games yet. But thought I would try the Prime95 test thing. on First attempt I had ticked the "Blend" test and after 4 minutes my PC froze.
Rebooted and tried the "Small FFTs" (which only ran for 3 or 4 minutes) and got the following (core temp and speedfan showing is after the test ended) :
I posted This thread about other problems, and info on the OC.
Not sure what this info means as I'm new to OC, should I try putting everything back on Auto/stock in BIOS and running the Prime95 again? I had Coretemp/Speedfan running during the test and CPU temp went to 64c, is that bad/average? My current OC temps are showing CPU at 53c. Pretty sure the HSF is seated correctly... didn't use any extra paste, just what was on it. Any ideas what my problem might be?
Any HELP much appreciated please!
650w decent power
Vista Premium
