- 9 Feb 2011
- Central London
Hello guys
I've recently overclocked my i5 2500K CPU to 4.2ghz (my first time haha). After running a test with Prime95 I noticed something strange and I'm not sure its normal.
Anyway after 30mins of testing, the temperature seems fine and maximum temp is 70c and at idle its avg of 35-40c. No errors are found. However, when using CPUID HWMonitor it shows that when Prime95 is undergo the CPU core is only hitting at 3.8ghz and not the full 4.2ghz. But when I stop the test my CPU seems to switch between these speeds 1.6ghz-4.2ghz.
Is prime95 meant to do this?
To note, when I overclocked I did not change many settings from stock. The only setting I have changed is that:
Spread Spectrum is : off.
Advanced Turbo 50: off
Interal PLL Overvoltage: off
Everything is stock/auto. I know that I need to change some setting but right now I'm not so confident.
Here are my specifications aswell
- Antec 300 case - (no front panel fans)
- MSI HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
- Corsair XMS3 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Quad Channel Kit
- Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366).
- ASRock Z68 Extreme4 Gen3 Intel Z68 (Socket 1155)
- XFX 750w PSU
- Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ / ST1000DM005)
Any help will be appreciated
Stefan
- XFX 750w PSU
Stefan
