prime95 on quadcore
21 Oct 2002
UK
hi folks,
just playing around with a q9550 and just checking the stability. Its been priming at 4ghz for twenty mins so far but I have noticed that a couple of the cores are a lot slower than the other 2. Only by 10 seconds or so but is this a problem? I thought I might be able to sort it by changing the gtl values but its not split cores 0/2 and cores 1/3. Cores 3 and 4 are the faster cores and 1 and 2 are the slowest
Edit: I am assuming that worker 1 is core 0, worker 2 is core 1 etc
I got this when running prime95 on various overclocks, dont think its a big issue. As long as a worker thread doesnt stop it should be ok.
